"Project Demons Breath"
oilburner
coboconk
holy crap:oops: what`s the back space of your wheels? any more than 6.40 to 6.50 backspace your rubbing bad. both my 18 an 15 inch wheels are 6.37 inch backspace. my 305-45-18 required nothing, my 315-60-15s needed the hammer cause tires are so tall. 18s far left banded 15s on right
The wheel likely matters a lot. You guys need to list your wheels when comparing what fits and how.
I'm curious if a 315 would work on my Weld 17x10s. I need to go look up BS.
My Welds are 6.7BS and 30mm offset.
Forgestar D5 Beadlock, 17x10, offset 30mm
oilburner
coboconk
just looked up your wheel specs, your backspace is 6.68 inches.
mine are 6.37 inches, the inboard bead on your wheel is just over a quarter inch closer to sheet metal than mine an the taller the tire the worst it gets were the metal curves at the frt of wheel well.
Thread Starter #1,985
oilburner
coboconk
@Hpindy can tell you what his back space is for comparison but looks like your back space is the same as fumanchu
Thread Starter #1,987
By the look of it your rims might have too much offset .
oilburner
coboconk
That's more then what I did ..... But I'm running poverty stars at the moment. 17 X 9.5
6.125 back spacing with a 22.5 offset
your wheels are much better suited for 315s.
the least amount of back space = more inboard clearance
the taller the tire = the least amount of clearance were the tread meets the sidewall.
Thread Starter #1,989
As much as I dislike these wheels they do fit pretty good with the 315's .
Yep, I think mine have too much BS to run 315 without some kinda spacer.
oilburner
coboconk
in order to swing these big gumball tires I would not go more than 6.40 inch back space
oilburner
coboconk
put the hammer away an buy new wheels with less back space;)
Thread Starter #1,993
I really miss my car already . But on a plus note I have a custom torque converter in my garage already and I'm just waiting on my new cylinder heads!..... Plus some other sneaky upgrades
I don't give up untill I have to. Today didn't work out but hoping for a track day tomorrow.😉
Just got back from a cruise in mine. E85 + HPIndy cam settings + 45 degree air + 555R G2 tires = sideways at half throttle lmao.
Thread Starter #1,996
More POWA !
Thread Starter #1,997
I hope you make it tomorrow. I will be on stand by
The DA should be way better unfortunately the baro will be lower than I would like to see this time of year.
Hopefully the rain pisses of so we can get it done. I doubt there will be any other chances this year.
Thread Starter #1,999
At this time of year it's hit or miss so any chance you get is better then nothing.
oilburner
coboconk
here ya go , this will make the pain go away ;) they dyno stock 193 hp
