Electric Pressure Washer
Av8ing1
San Marcos
2019 Charger Hellcat
I need a new electric pressure washer. I'm tired of the crappy gas one I have. I have used a Sun Joe, borrowed, and wasn't really impressed. So any suggestions? Primary use would be washing the car. I'd rather pay more and have a decent piece of equipment.
Challenger
I've been very happy with my Sun Joe SPX3000 and I've tried many before.
landoawd
Hillsborough
Price per $$, SunJoe electric.
I have an AR Blue that has been great, but they use a proprietary mounting system on the lance, so it took some doing to rig the foam cannon.
I got a cheapo SunJoe with an adjustable tip, does the job (you don't need or want to use a lot of pressure on the car).
Detroit
Afghanistan
what is a small, compact unit one could ostensibly have in the trunk and power from an inverter from the car charging system? Doesn't have to be industrial grade, just enough to quickly deploy and spot-clean the car if needed.
Detroit
Afghanistan
Thanks for the information!
Av8ing1
Av8ing1
San Marcos
Responding to my own thread:
My borrowed Sun Joe turned out to be fine. I was having issues with operator error and a long garden hose that was full of air that caused some frustration. So I can't blame the washer for anything. After it was returned I ended up buying a Powerhouse International electric pressure washer (supposed to do up to 3k PSI and 2.2 GPM.) on Amazon. My research was that all these units are Chinese quality and a bit of a crap shoot. The Powerhouse had good reviews for support (small home business run in US.) I also wanted a hose real and high flow rates. It works well and I've had no issues. That said in this price range probably any unit will work fine for car washing. I'm the type that will spend a bit more to have a tool that lasts. I doubt high quality, when it comes to electric pressure washers, is achievable without spending way way more for a professional machine and car washing isn't that critical to me. Anyway, thanks for all the input guys, much appreciated.
