Sign Up! To view all forums and unlock additional cool features
Not surprised from what you have. Probably not loosing much power with e70 over e85 from what I know. Not sure what is going on with the 60 ft unless the prep is really bad. You have the 315s and AAD arms correct?
Switched to left lane from right and spun half the track prep on that side was horrible horrible. Unfortunately ran out of fuel can’t believe no one sells e85 jugs there
Look at that shiny new 9 second et banner.
Same for me about the e85. I just switched mine to e85 a couple of months ago. With the lowered mpg and the 70ish mile drive to my local track I'm thinking I'll probably leave the house on a full tank and bring extra fuel with me just in case.
Thanks man! Fastest I’ve ever gone, lots of work to do still car has a lot more in it, thinking 9.5-9.4 with some more suspension work and testing. I just left off idle and stabbed it, 22 psi in rear tires. Was also 88 degrees
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
