Traction control problems?
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
I hold down the traction control button for several seconds and sometime it turn off completely but not ever time. My car is a 2016 challenger. Is there a glitch that make it works sometime and not other times you reckon?
What kind of Challenger?
rookerrobert
rookerrobert
Ridgeland
SC
hellcat....when I had my scat pack it worked every time. But this hellcat might work might not. And you can hold the button down as long as you want and the traction control says off but it's not
What about your drive modes?
It might depend on what mode you have your settings set for?
I think he has it in street mode.
rookerrobert
rookerrobert
Ridgeland
SC
you can put it track and still has some traction control....there's 2 lights one will come on but to the left of that light there's another.. and if it spins a little to much it will come on. I have tried in all drive modes. At the track I run track traction,trans on track and susension on street custom setting.
zhc
7 Second Best E/T
2016 Dodge Charger Hellcat
If the traction button responds to your presses but doesn’t want to turn off completely after holding it for 5-10 seconds, that usually means there’s a fault somewhere, like with suspension or abs. Use a good scan tool to look for codes stored or active in either of those modules.
Personally I use traction control.
rookerrobert
rookerrobert
Ridgeland
SC
My first run was good and traction control was off ran 10.97@ 127 after that 2 runs at 11.23 and 11,15 and the sixty on the 10.97 run was 1.50 and the other 1.80+ tires had the same air pressure in all runs
rookerrobert
rookerrobert
Ridgeland
SC
yep I agree...I'm going to send my ecm off qnd have it unlocked and just take my hp tuner and turn it off in the tune
rookerrobert
rookerrobert
Ridgeland
SC
I do like to do a good burnout at the start and then just haze the tire after
I still do a burnout. Well, more like a scuff.
Might be heat?
rookerrobert
rookerrobert
Ridgeland
SC
yep that could be possible also...and maybe even track prep or he lack of prep It was a street car event and the longer it goes the worse the track gets
Any of those things. These cars produce a lot of heat.
