Wheel Spacer
VANCOUVER
2018 Jeep Trackhawk
New owner of a 2018 TH, notice a lot of stock wheels sitting flush. What size spacer is everyone using?
Don't know about TH's, but my 19 challenger actually has 11. 5 rear wheels and 10 on the front.
On my 16, I had (either 1/4 or 1/2 spacers, can't recall).
I do have them for sale here.
If you get them, you will need to swap out your lug bolts.
Ive never used a wheel spacer for either the stock wheels or Velgens. Where are u getting this info from?
I have 20 mm pass thru spacers that I ordered to be made for my 16 hellcat. Ordered longer than stock (1inch, cuz I couldn't find 3/4 inch longer than stock) lug bolts.
I had 3/4 inch (with attached lugbolt spacers). But a they are mounted on aluminum spacers, the bolts tend to offset.
I used them because I have Phillips performance fender flares (on my 16 and 19).
I was using them because I had 10.5 inch rear wheels and 10 inch on the front.
Don't need the spacers anymore because I have 11.5 inch wheels on the rear and 10.5 inch on the front.
