Another one for Jon Moored
At this point, I'm probably not telling anyone on here anything they don't already know but Jon is such a fine tuner that I feel compelled to say something.
I came to Jon after frustration around the Dodge Direct Connect packages. The shitshow of a rollout, the higher than originally quoted cost, the lack of support I'm now seeing for those with problems...I ended up saying forget it. This meant my only option was to take a walk on the dark side and (probably) void my powertrain warranty. After setting a personal best ET of 10.5 in about 200ft DA this spring with my stock car and knowing I'd probably never see that time again but still wanting more, I contacted Jon about his performance packages. Given the overwhelmingly positive sentiment, his knowledge sharing posts around here and his own personal 8 second car, I didn't bother looking anywhere else. Another member who Jon has tuned for also vouched for him with a resounding thumbs up.
We started via PM, then moved to text. Even had a phone call. It was special, a whirlwind relationship, even. Before I knew it, I had a stage 2 performance pack from Jon ordered and on its way. I had the pulley and injectors installed locally at a shop that also exceeded my expectations and probably deserve their own shoutout for a great experience. Jon was able to accommodate the timing of the install and had the base file ready for me to load at the garage. Jon is a very iterative tuner which I appreciate and had me do a quick idle log for him before I got it on the road to make sure everything checked out. He reviewed the log in real time and gave me the thumbs up to drive it home, again logging it and with no WOT throttle allowed.
The drive home was uneventful, which is all that I could have hoped for at this point. Jon then quickly reviewed the log I had created on the way home and had another file to me the same day. I loaded this file and was instructed this time to give him a quick 5500 RPM hit for a fuel check. He also reviewed this almost in real time and had yet another file for me in short order, this time instructing me to give him a WOT pull.
"Ho-Lee-Fuk" was my only reaction. I don't really remember, I was too busy white knuckling the steering wheel as my car rung out gears like I've never heard before and shifted harder than I had ever felt before. "that's the base tune" Jon told me "It will pull harder yet." All I can remember is thinking "this guy is a maniac, there's no way it gets faster."
Well, Jon sent me another revision in short order, this time actually adding timing and I'll never forget the first WOT. Viper vibes is really the only way I can put it where the car feels like it's out to kill you. It truly was a next order of power I didn't think I'd feel with just a pulley and a tune. It's so obvious that even non gear head passengers can tell something is very very different about my car now. I had to go out and buy Nitto's for the rear because the Pirellis were giving me burnouts at highway speed, I kid you not.
In an effort to wrap up this novel and bring it home, I'll just tell you that the rest is history. Jon and I spent several more revisions working out little kinks and personal preferences related to throttle tip in, etc and it's since been perfected. Jon identified a small amount of knock on one of my logs taken on a very hot day and told me that even though it's probably "false knock" lets play it safe and pull a degree of timing and he sent me a revision quickly which I appreciated as I'm looking for a reliable tune. Without a doubt, my car now runs better than it did when it was stock, more akin to a finely tuned Rolex at wide open throttle. The character and drivability of the car has been entirely retained while adding another massive level of power at WOT that still leaves me laughing after a good pull.
Jon and I are now working on an octane booster tune for the track. I was able to set a new PB of 10.2 @131 MPH two weeks ago in 2700 ft DA, beating my previous PB of 10.5 and doing it in god awful air, cementing the fact that this is an easy 9's car in better air. That's what I told Jon I wanted and that's exactly what I got. Jon is so responsive that he was actually able to take a look at a log, identify an issue that cost me about a 10th on that run and sent me a revised tune while I was still at the track. Unfortunately I wasn't able to get the car to hookup again that night so I wasn't able to get that 10.1 or 10 flat that I'm sure I could have. I know I'll get that 9 second pass before the season is out.
In summary, Jon has been excellent to work with. He is highly available, even spontaneously as with the track night I mentioned above. He is absolutely and unequivocally an expert hemi and hellcat tuner and knows how to get these things moving with both engine and trans tuning. His work has transformed my hellcat from a beast to an apex predator and I am very grateful for his service. He is a busy guy and a family man but his dedication to my tuning project as if I'm his only client has been incredibly impressive.
Cheers Jon and thank you for a job well done.
Bowler, maybe I missed this, but if you're in a Charger why doe you have a Challenger avatar pic? Just curious.
Paladin, it just hit me. You have those shields under the tracks to prevent drips and such from the rolled up garage doors? Right on man!
MXS67454
Tampa
Dodge
My DD 18 Charger R/T with an Edelbrock 2650 SC was recently tuned by Jon thru a shop here in Tampa. short story. ..car ran great when I moved from WI to FL.. installed a smaller pulley and bigger fuel pump. found a well known Hemi shop in Pompano Beach to tune and they created nothing but problems.. with the smaller pulley they said it picked up 40 whp yet the car lost 8 mph trap speed . they tuned it again and the car slowed down more and had numerous drive ability issues. Jon fixed all of it and the car runs and shifts better than it ever has. .. once the summer heat is gone I will get to the track for the rest of the story.. I'm looking hard at a MMX 392 long block and I definitely want Jon to tune it.
20HCM6 22RENBS2
After reading BG's post, am I the only one who feels like I'm missing out on an important life experience by not voiding my warranty? :(
Hatermkr
West bend
2016 helldemon
I have a guy that’s a so called friend that’s all I hear is about his warranty. But he wants more than 10.5. That means you get p1400 and go to town
Bowlerguy92
Bowlerguy92
Thread Starter #26
That was taken at Radford Racing School. Just thought it was a cool photo since it’s such high quality and was a unique experience!
Bowlerguy92
Bowlerguy92
Thread Starter #27
Here's my actual tuned and pulley'd ride though, for curiosity's sake @Magnified
Friend or someone you know:unsure:
Does the name start with an A?
RGPIII
Bridgeville
DE
Then you will complain you are too busy:unsure:
yup he's already getting too big for his britches. I think the fame is going to his head! :ROFLMAO:
MXS67454
Tampa
Dodge
It does ! ...I'm guessing I'm not alone in my troubles with them but, at least nothing broke.
Mine was a short relationship.
20HCM6 22RENBS2
You washed the wheels! :ROFLMAO: Looks great!
Is this cars and coffee at the mall?
Looks like a trailers and coffee going on over the other side.
20HCM6 22RENBS2
Well, you know, malls are struggling these days... :)
Bowlerguy92
Bowlerguy92
Thread Starter #37
I’m going to make sure they’re extra dirty next time I’m at NED, just for you!
That second photo is at NED.
NED stands for Northeast Division in the NHRA. Land of NED.
Jon is a hell of a tune and a hell of a nice guy !
Sent from my SM-S901W using Tapatalk
