Challenger Hellcat A/C help
D
Demid22
Nurse
JONESBOROUGH
2017 Dodge Challenger Hellcat
Thread Starter #41
Frash presser, large $$ end 1st but save time wit da rest. Have youz testacal da delter t in er yet? Youz bee lukin fer 17 whore bettah. Dat wood sayve alot of time wit da cumprasser. Dat wood tell alot. Slut engagen mint, all waz luved dat at Diamund Dulls, slut engagement, hate engagements wit no moe, refrig lines cum taminateded, whore cunt controlls, hate dat. Wishet I wuz dare 2 help.
Changed out expansion valve and replacing compressor in the AM. Back flushed the system to clean out any debris it may have had in it. Will keep this thread posted. Thanks Hicks. I wish you was here too lol
Eye dew thank 134A will bee a round fur a few ears. Reememba 2 flush da lines wit da same refrigeration stuff. Dis spell reedisplacement sucks. Want 2 use da same stuff fer usin. Ubee du en guud. Process of eminitnations, whore e lluminations. Buth da same. I'd thank aftah 3 asses of da wine. No shine ette. Waiten on Dave tu show. No Dave. Kno shine,,,, yetsturd.
Is it working yet? You’re supposed to add a few oz of pag oil as well. They sell replacement TXV valves and high side pressure valves for a reason, could have went bad
After talking to a lot of people on this subject, I’m going with an ice box. Won’t heat soak everything else, and you can get an ice box and a cwa400 pump, all lines/fittings for $400 less than then cheapest chiller (cheapest of the good chillers)
And, it works well with your heat exchanger - no need to bypass it. I have heard that your IATs can go ABOVE what they did without the chiller if you don’t have enough filled coolant at the top end if you bypass the heat exchanger, which you typically do with the chillers
So, you need a $1800-2000 chiller, a $400-650 aux tank, and a $450 pump to handle the additional head pressure a stock pump can’t. Chillers are a money pit.
I HIGHLY DOUBT IT JUST WENT BAD WHILE SITTING ,START OVER WITH IT FROM SCRATCH AND PUT THE CORRECT AMOUNT OF FREON IN IT ,ONE CAN ISNT ENOUGH WITH THE CHILLER ID IMAGINE ABOUT 24 OZ AT MINUMUM THEN READ GAUAGE ISNT MOST CANS ONLY 12 OZES
OH AND I RUN 134 IN MINE ,NEXT IM TRING R12 JUST TO PROVE EVERYONE WRONG :ROFLMAO:
Yepper. Beez shure youz insulate da box and lines sew youz don't have a mess. Rubber and Armstrong 520 glue wit Armaflex rubber.
Youz bee all rady wrung cause youz bee frum Mumpfus. R12 my assatone. Don't make itster any moe.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #50
Im aware and it was replaced
Just trying to help man
Just strange it stopped working after a shop did work to the car
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #53
Yea. I changed out the compressor, drier, and expansion valve. Charged it with 1200g. It worked about half way if that makes sense. Certainly cooling but not like it was. Pressures were 80 low side. 150 high side. I might go ahead and buy a pressure switch as well. Im unsure whether itd work "half way" if it was bad but at this point im lost.
I know it was working before and the only thing in the area i was working is the pressure switch and where i extendes it for the chiller. Ive looked these areas over extensively and checked what HP tuners sees. See above pics. Got a guy looking it over as well. Will post back when i find something. Once i get it up and running ill update my build thread with the whipple and new tank and cwa. Its a sweet setup.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #54
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #55
Anyone know what voltage the pressure switch should be showing on HP tuners? Im only getting a volt or. Just under.
80 on the low side is high, 150 on the high side is on the low side running. Is this with chiller and cabin AC on? What is ambient temp where your testing? What for new compressor did you use?
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #57
This is with both chiller and cabin AC on. 90 degrees here.
The high side would be sweet at that pressure, I assume auxiliary fan is running on secondary condenser? Try taking some Freon out until suction pressure is 60 psi max and see what it does.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #59
Yes all fans are running
Any difference in pressures with drag valve on and only chiller in the circuit?
