Live action from FUMANCHU182.
Smooth controlled burn outs with both wheels spinning is the key.
Those clutches burn up real quick when only one wheel spins and you don’t realize it.
One way you can tell you’re only spinning one wheel is your speedometer will be reading much lower, like half or less than expected for the rpm and gear that you’re in
Do you use a line lock or gently drag the brakes.
I have found I would spin one wheel when I used the line lock so I stopped doing that.
Good to hear on both!!
What axles you using?
Thread Starter #1,883
The only axles worth a damn. Demon axles.
HMBRGLR
Stockton
2022 Challenger Hellcat
how much of an advantage of it is to lose the swaybar?
RGPIII
Bridgeville
DE
less weight on the nose, more weight transfer.
HMBRGLR
Stockton
so like .05 in the 60ft?
Not on my car it wasn't anything noticeable.
RGPIII
Bridgeville
DE
You cannot compare a stock car. When I was slightly modded it seemed with the sway bar off I had a harder timing hooking. I assumed it was a really fast weight transfer up and the car didnt have enough power to hold it there and it slammed down. IDK. Not a science I wasnt at that power level long. Sometimes you have to do your own testing.
HMBRGLR
Stockton
I guess MIR can be a test for it then. Maybe i will get under the car bfor than and take it off
Sent from my SM-N981U using Tapatalk
That is what I found as well as a friend that has a modded 300. So I installed the sway bar out of my wife's charger rt to get that to stop.
So there is some weight savings still but the front end isn't free to do as it wants. LOL
@jonx96 according to an expert on the other forum my car is basically a promod. LMAO
RGPIII
Bridgeville
DE
hahahah according to Jon everyones car is a promod!!
Thats according to you. I have done nothing but street drving this month
RGPIII
Bridgeville
DE
all them fumes getting to your head? cant read anymore? haha :LOL:
I’m just hungry 🤣
Thread Starter #1,898
So for all those trying to wrap their head around what a Wavetrac is, it is a spin on the Quaife ATB. ATB stands for automatic torque biasing. Mansplaining commence...
1.) Right wheel spins, left wheel is a star fish.
2.) The helical gears in mesh transfer power, i.e. right side gears now engage with left side gears.
3.) Left side gears being driven by right side gears now spin the axle on the left side.
4.) The wavetrac however has an internal cam due to the wave design
Thread Starter #1,899
Drove the car, diff is no louder than than what I was dealing with. Since its gear based the power is instant.
I did make a quick hit to accelerate past a goonie, the power was there, wheels didn’t spin.
So is the the ring gear/pinion mesh that make these loud or the carrier
