Sign Up! To view all forums and unlock additional cool features
I have seen a post about this somewhere here and I just cant find it. This rubber connector is going bad on my HC and I would like the info to fix it. Thanks, everyone!
Hit up @Diboblo with a PM. He had this happen to his car a while back & as I recall had to order a whole box to get the 1 he needed.
He was giving them away at the time as I recall.
It has dry rotted and every time you touch it,, will get worse. There is a way to do this. Wish I had a video to show. This is on the rubber elbow that has pulled loose from it's connector,, correct? If so easy fix.
Since it will be rubber again. I wood advise to coat it with a rubber based coating you can get at home depot. Just let the paint dept know what you are using it for. I have a quart here specifically for rubber. Called Armaflex white coating. But you can tint it to any color, they will do it for free.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
