Watt ching the Bucs and Cow Girls tussel in Tampa. I still have no clue of taking my back seat out until the double turbo trans formation. After I get my guns back. Soo wee, in the mean time, I am going to have me a shake and the last bit of shine. Store tomorrow. My town home faces due west. Hot as hell. I have a 2 car garage that eats the heat. I have the door 3/4 ways of 3 layers of insulation and just got the finished layer in. All white and doubleded tapped in. You can only do this attempt a few hours a day or over heated. I think by Monday I will be done. Then let's see the effects. Then I may tap off the supply air in the kitchen and head to the garage. Install a adjustable damper to close it off or open it more. I have 2 working ceiling fans with fans in the garage. It helps so if I just dump a bit of conditioned air in the space will help. My a/c unit is grossly over sized and I did that for a reason. I cut in 3 more return grills in up stairs to draw the hot air off the facing west wall. All windows. Had them tinted. No good. Bed rooms up younder were runing 92 degrees. I cut the returns in and insulated the damn winders with heavy window curtains over that. Ya, ya, that saved the day. 2 dehumidifiers with no This is where I get my chiller experiance from. This stuff. Plus UV light in the AHU, 4 through out the house, 5 stage air filtration machine in the master bed, and a 5 stage charcoal variable speed machine from living room to the bed room. No wonder they can't kill me at the hospital.
