Not sure where to post this particular question
Las Vegas
NV
2022 TRX
Hello,
I recently upgraded from a 2018 Rebel to a 2022 TRX and I noticed the front when purchasing, but I’m not sure what the previous owner had connected at one time. I just know this doesn’t have the typical rings that the other models.
P
Las Vegas
NV
2022 TRX
Thread Starter #2
Sorry, thanks in advance to any help.
Hello,
Jeff ole boy....ya just joined 30 min ago...how bout warmin us up with a better intro before ya start pickin our brains...:unsure:
Demoniccat
Mid
RI
Plow hitch receiver ?
Tow bar mount?
72 440 Barracuda
Graham
Looks like this was towed behind a Motorhome...
I have the same mounts on my car I tow behind my motorhome.
P
Las Vegas
NV
2022 TRX
I didn’t even think about someone towing it. Thank you!
MMissile
Macomb County
2023 Challenger Hellcat WB
That's why it has the trailer wiring plug.
Transmission is probably destroyed
From not doing anything other than going for a ride while not turning?
Should be less destructive than driving the vehicle.
Have you ever seen what towing does to a Jeep transmission when towed improperly!!?
Lots of things can be destroyed if doing things improperly.
Those who can spare the time to read the owners manual and do it the right way shouldn't have any issues.
72 440 Barracuda
Graham
I was curious about this and according to this it can be flat towed:
"I plan to tow my TRX flat (all wheels down) behind the coach at times (yes, Stellantis says it's designed to be done so - Neutral position on Xfer case selector for just that) - before I trade in my '19 Ram 1500 that's got the brackets mounted to it's frame to tow behind coach, I wonder if anyone has tried using the Blue Ox brackets on their TRX that were designed for non-TRX 1500's?"
Link;
https://www.ram-trx.com/threads/flat-towing-trx-behind-motorhome-question.1397/
looks doable, as long as it's done right, of course...
04Ram2500Hemi
Western
MT
2021 Ram TRX
Words of wisdom by @Jimmy N.
Very Wise!
Pull towing is one of the worst things you can do to a car. The transmission pump isn’t running, so it’s not pumping fluid through the trans cooler.
With the transmission not turning, there's no reason for the fluid to get cooled.
The driveshaft is still connected, the transmission is still turning…
Yes, the driveshaft will still turn, but with the transfer case in Neutral the transmission won't.
Actually, as I recall it should be in Park.
I would definitely trust a used vehicle that was pull towed to have been done correctly
Me too. Because it's either just fine, or has a new transmission.
