Let’s build a race car
Am I insane?
  • Total voters
    18
Are you going to insulate the fuel lines more? Cool fuel does make a difference (although you’re running e85 probably)
Thread Starter #522
Nope, this is race car, we don't need to add weight.
Thread Starter #523
Up next is welding on my fuel cell or mounting the oil cooler…
Mounted in a ts/sci location 😂
Thread Starter #525
Taking a break from the fuel system setup. Getting back to the electronics.
@HolleyPerformance #dominator mounted!
Its my dash I can drill as many holes as I want into it 😂
Thread Starter #527
Would have put it elsewhere. I'd get sick drilling holes in my dash.
Like where, considering I sat there thinking for two hours. Let me know your solution?
I would put a CF plate there and attach them to that instead of individually to the dash. CF looks professional 👊😆
Thread Starter #529
Made some good progress over the weekend. Unfortunately a shit ton of bad news about the dyno…
Lastly, please note the current ETA to Los Angeles is September 28th and to Baltimore it is October 20th.
Fake news this looks like a street car! 😂
Thread Starter #531
it is technically, registered to my Montana LLC and has tags.
Under the dash on a bracket?
Thread Starter #533
Oh sweet summer child. You think I wouldn’t have tried that?
The unfortunate part of the Hemi harness from Holley is there is no slack in the ignition modules… aka…
the plugs cannot be moved
Explains why so many race cars have wiring all over the interior
What’s up with the dyno?
We placed all of the hardware on a panel with the ecu at the top and the plugs facing up. The harnesses have enough slack that the panel can be unbolted and moved to the floor to access everything. On the Magnum, the panel is placed horizontal behind the glove box opening with the ecu at the rear. It can be pulled out like a tray for access. Basically it’s a race car and you can do whatever works. Personally…. I dont think any two should be the same 😎 IMG_3975.jpeg IMG_8313.jpeg IMG_4998.jpeg
Thread Starter #537
fans are in and wired
Thread Starter #538
2-step on a holley is stupid easy. Knowing how to gate it with virtual switches and safeties… a descent into madness
#Holley makes #2step installs easy
I look forward to these updates, looking solid man
Thread Starter #540
Little preview, fabbing my own mount for the hellcat oil cooler.
