Blower Spacer Plates
WhipCat
In the Jungle
The whipple will need spacers for stock hood. Motor mount or cross member spacers will do the job.
I also haven’t seen any boost pick up from the spacer plates, and I’m not sure how the plates do for the IAT, but I installed chiller at the same time. When I was running crazy boost, over 30 psi, I had oil pushing through the supercharger gasket, but!! This was not due to a design flaw or failure on the stock blower gaskets, just an issue with the thitek heads and they way they were designed. This was fixed easily though.
I did a half mile recently since the chiller and checked logs. We went from have 150-170 at end of 1/4 mile and 180-200 degree At end of half mile IAT in florida heat, that was before.
With the chiller active and large reservoir. We went to 131 degree IAT in super high heat at the end of the half mile. We picked up a 50-70 degree temp drop because of chiller and potentially the accompanying mods.
I just installed spacers tonight 😃
