Downforce and alignment
sorry about the hijack.
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #22
No problem. Had a h.a. Six yrs ago. 6 stents. My best friend 22 years ago had a massive h.a. at the drag strip. I gave him cpr and the firemen paddled him. No good. Only 42.
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #23
So I spoke with the owner of the alignment shop. He said to fill it up with fuel as I would do at the track. He has a simulator that can put 200 pounds in the drivers seat. Then he will work on getting rid of the .26 toe on the drivers side. He will make sure the tie rods are tight, bushings are good, etc. then hopefully get that to about zero. I am going to drop her off Monday afternoon.
Sounds good. Good luck.
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #25
Positive front toe is counter intuitive. That actually means the front of the tire is pointing toward the center of the car. So at .26 positive no wonder why I am battling the wheel left at the big end.
You need to get some AAD arms on your car/ Based on what I see you would want 6 tab on driver side and 5 on passenger side. That would get you to +.20 or so on each side
I run my car around 1/2 tank at the track so I took it in that way. Parker at AAD didn't seem to think it mattered much about weight in the car when doing it
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #27
In the front AAD only makes them for the upper arms which I have. AAD tells me it has nothing to do with toe. I was told by zach at aad he likes the toe at a .10. All I know is it did change a hell of a lot with the simulated driver. Went to .26 on the drivers toe. Probably a worn ball joint. They will figure it out. I have the AAD in the front.
