IC Chiller install & review
Thread Starter #61
don't go plastic unless you have the time to keep tightening them and chasing small drips.
Good info, thanks for the insight man
Ptfe paste and call it a day. Nary a leak.
Welp, I need to get different fittings for the water lines into the brick. I received metal 90 degree fittings as opposed to the plastic ones I typically see with this kit, and they only want to thread in 1/4 of the way, stick down way too far, and will become too loose if I try to index them the way I need them. Anyone know where I can get plastic chemical/heat resistant plastic 90 degree 3/4 barb to npt fittings? They really need to put AN fittings on the brick.
Try McMaster, they usually have everything lol
Thread Starter #64
They have the plastic fittings, but ones that are too long. Everywhere is out of the banjo plastic fittings that usually comes with the kit, of course. I found what I believe to be the right fitting to use on this, but they’re $75 a piece
Thread Starter #66
Since no one ever has pictures of how they plumb everything/mock it up before install, here you go!!
mill be adding color to the hoses/direction and theory of operation after I mount chiller, soft mount fittings and take more picture. Have never seen any without the brick installed that shows full line plumbing. Yes, I left hoses long as this is for mock up. Let me know if there are any questions - this is based on ICs updated plumbing
IMG_1607.jpeg IMG_1603.jpeg IMG_1602.jpeg IMG_1600.jpeg IMG_1601.jpeg IMG_1596.jpeg IMG_1604.jpeg
Thread Starter #67
Right is hot, left is cold.
Straight up factual lie, my thread brings all the mechanics to the yard, my install is better than yours… 😂
Thread Starter #69
I have used yours though, lots of good info
Thread Starter #70
Valve off/default open position (normal open)
Thread Starter #71
Flow. Blue = cold, Red = hot (return from supercharger), Orange = heat exchanger
Thread Starter #72
I used the double zip tie technique, I think that qualifies me as a mechanic 🤣
Thread Starter #73
I think with the new plumbing the theory is that the pump is always pushing fluid into the chiller/chest exchanger instead of pulling from it. Not sure why, would be nice if someone had results of plumbing like this
Thread Starter #74
Imo the 3 way bypass doesn’t do much at all because you’re still plumbed into 1 side of the heat exchanger
Thread Starter #75
With brick
Thread Starter #76
With brick and TXV
IMG_1628.jpeg IMG_1629.jpeg IMG_1630.jpeg IMG_1632.jpeg IMG_1634.jpeg IMG_1637.jpeg IMG_1636.jpeg
Thread Starter #77
If anyone has any thoughts as to the theory of operation or suggestions on my plumbing I’m open to it
Plastic uns is great. Mealuns are a pal in daz ass atol. Uz can paint du ones a meal finish if youz wish. I have delt witha lots of metal finished been a medal finsher allz my life. Industrial metdl finsher all my life.
Thread Starter #79
Oreilly’s for the W
Thread Starter #80
