JXB center driveshaft bearing causing vibration
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
Hi Guys. I installed the JXB center bearing on my perfect driveshaft on a 21 Charger RE because I am adding horsepower for this season. Well, I got an instant vibration at 80-85 mph. The cause of the problem seems quite obvious....the driveshaft is now pushed WAY over to the drivers side. The mounting bracket is already solid against the passenger side of the driveshaft tunnel so it cannot be adjusted any further. And the mounting bracket does not allow for removal of that amount of material to get it right. So I ruined a perfectly good driveshaft for nothing and am installing a new one this weekend.
I have contacted JXB and am waiting for a reply. I did trip over a bunch of guys on another thread somewhere with the same issue, but the thread was not under JXB. So I started this one. Maybe if enough guys post that they have the same problem JXB will make a bracket for us that fits cars with this issue. I have to assume that for some reason our driveshaft tunnel is off a bit from the factory because most guys do not seem to have this problem.
Pictures of the issue? The redeye driveshaft is stronger then the hellcat and will go low 9s
Did you not cut all the rubber off?
The driveshaft is always offset, it’s not straight in there.
Sabina
2020 Chrysler 300 HC
I have a hellcat 300 and installed the JXB carrier and i am having the same problem. There is a silver ring on the driveshaft now from where the driveshaft has been rubbing on the carrier bearing... making me wonder if the carrier bearing is causing the driveshaft to be in a bind? I have bad vibrations above 60 mph+ and i alot of vibration when i start accelerating and when i let off gas. I cant figure out the issue. I have seen other post/ videos about the upgraded carrier bearing rubbing on the end of the driveshaft, but no one ever says what really was the source of the problem.. Im lost.
It would really help if people with the issue just threw the car up ⬆️ n the air and took pics so we can see if anything looks off
At transmission, at driveshaft, and the carrier bearing. Snake a camera or horoscope over the heat shield
Thinking a few put it in backwards. Some things have a orientation and could easily be installed backwards by keyboard warriors who really should t be working on mechanical things. 🤷‍♂️
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
I took pics yesterday when changing to a new driveshaft. The new driveshaft took care of the vibration. However, I think it was from the soft rubber bushings used around the mounting bolts for the JXB bracket. By hand it was moving all over quite freely.
I realize that these driveshaft joints do need some side load on them or they will vibrate more if they are totally straight. I need to figure out how to get pics on here from my phone. Yes, the factory unit is also towards the drivers side, but the JXB visually appeared to be a little bit further to the drivers side. I was trying to figure out a way to measure it, but we were in a hurry and didn't have goofy stuff laying around to put something in place to measure the two. My bad, I am regretting it today.
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
That was the JXB will try to get the stock now View attachment 163648
If I were a keyboard warrior I would be able to download more pictures properly.
Glad you got it figured out man. Yeah, I think if you don’t get all of the old rubber over around the bearing it’s going to wobble
Did you try torquing the bolts down more so that’s there no play in the carrier? It should be pretty solid, the rubber shout just be for isolation to prevent noise
Looking at it, it looks like the one side is torqued more than the other side
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
I'm guessing that was the problem. Those soft rubber half grommets were not squashed down rock solid, and the bracket could be moved by hand. Oh well, I guess its always nice to have a spare driveshaft laying around with these cars. Its too much work to remove the exhaust and change it back to test.
Thanks guys.
Anytime man! Yeah, never bad to have a spare
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
JXB contacted me today with lots of information. They have an updated bushing and a lower bracket that they are sending out. They have a lifetime warranty on their product and it was nice to see the support from them. Glad I got in before the prices went up.
