"Project Demons Breath"
WhipCat
In the Jungle
Why copper?
Copped is a better conductor than iridium and platinum. And it dissipates heat better.
this is good for high boost and/or nitrous, less chance for misfire.
the downside is these probably will not last as long so they need to be changed more Frequently
motorhead
Ottawa
2019 Challenger HC Widebody
Get out of my head! I cannot afford to share a brain.
Once the echo chamber around here catches wind of this there is going to be a stockpile of fancy plugs laying around.
Thread Starter #703
@WhipCat @motorhead some of us are to lazy to change spark plugs more often . Especially on a street car .
The drivers side isn't bad . On the passenger side the supercharger coolant lines are in the way .
I think I will test my patience and do the 2 Turbo Buicks at the same time.🙃
motorhead
Ottawa
"STREET CAR"
I have had the same copper plugs in my blown TBSS since Jan 2016. I might look at them this Spring once the HC is out. Might.
Thread Starter #706
"STREET CAR"
In my case I'm going to revert back to the lazy part
Thread Starter #707
Gluten for punishment eh
WhipCat
In the Jungle
Lol. The key is to keep checking them.
i think if I was gonna be spraying often and running my smaller pulley to 30-31psi then I would prolly change every 60 days.
but since I’m street driving almost every day right now, and running 23-24 psi. Haven’t even sprayed yet. To nervous lol. Finally gotta hit it soon. I should be good for a while.
still messing with the pro Max controller. Then need to take a data log of a top end pull 100 shot through 4th and 5th gear. See how it looks after.
motorhead
Ottawa
Can you share the Accel part number?
WhipCat
In the Jungle
Thread Starter #711
Spark plugs are done , hood is painted and hopefully picking it up next week . I really wish FAS had the 2.7L billet bearing plate ready...... Talk about a perfect time to install it!
motorhead
Ottawa
This video helps explain why using copper plugs can be beneficial (hint: it's timing tolerance and power potential).
Stop with the plug post I’m having flashbacks 😂
motorhead
Ottawa
Got a link?
Thread Starter #715
Here is what I did today . I will get an alignment and shoot .0.5+ camber in the rear .
Thread Starter #716
I'm still waiting on my supercharger to return from porting so now I'm going through everything else that need TLC or sneaky upgrades .
Damn you got the aad arms I’m wshkngbi had them now bmr service has turned to shit
Those look well made. Plus they look badass. Stop making me spend my money dammit.
Thread Starter #719
But mark ..... I love spending your money . It's a non intrusive install . I did one side at a time . I just lowered the cradle enough the get the front bolt out . It's wasn't to bad at all . The factory front upper control arm is really flimsy and bugs the hell out of me . Once we get to the track I will let you k now if it's worth the money .
. If we get to the track I will let you k now if it's worth the money .
See what I did there😫😡.
