Who got lights...
DRAGRCR
VICTORVILLE
MANGO D170
Airbag/seat belt light = easy fix ( someone makes a bypass harness).
Tpm = easy fix ( can be disabled )
Why is your ABS on?
Check engine lights can be turned off in tuning .
You forgot the Windshield washer bottle low level light. I am on my 3rd edition of the bypass plugs now.
tkracing1
Bay Area
2017 challenger
First thing I noticed was the 3.2 MPG.
EEEK
Thread Starter #24
Haha. Yep. That’s what happens with a 4000 rpm stall torque converter. And that has been on $8 a gallon Ignite because that’s what I have in there with the tuning work we’ve been doing. I’ll be using the pump e85 I have to ease the cost of that until time to get to the track. As I have been learning the car with this new trans I’ve figured a way to improve that fuel mileage some. The trans freewheels when I let off the throttle. It’s like pushing in the clutch when you let off the gas going down the road. Makes for some fuel efficient coasting.
Thread Starter #25
You know what! That may be the one light I have to deal with. The rest of them just sit there minding their own business. That damn little sprinkler intermittently chimes and takes over center display with a warning that I’m low. Like it’s an emergency situation. I have to hit the left up button to put it back in its box. I’m just about tired of that :mad:
Finally now we are getting somewhere .....
Hmmm:unsure:.
Low washer fluid light. For someone that gets accused of stripping the car. I should know where that light is.:ROFLMAO:
New mods for me this year are, run low ww fluid and remove the compressor from the trunk. Thanks for the idea Marc.😀
Ya those lights would trigger some kind of emotional breakdown for me.🤣🤣
Hmmm:unsure:.
Hey Jim
You have the Alfa obd have you tried it on your cat yet?
Hey Jim
No I haven't looked at it on the cat.
You know me I'm always afraid I'm going to f' something up.
I'm working on getting brave enough to install my cradle lock out.
Lol . You got my number for a life line on the install . It actually quite easy .
I wonder if the Alfa obd could see the tcm and bcm and disable or change features? Is the Alfa obd locked to 1 vehicle ? This is a great topic for the people with OCD and dash lights.
Thread Starter #31
No it isn't locked to a vehicle.
When you plug it in you link it to the car like any code reader. Then you go through the modules you want to check. Either for codes or scanning / logging.
I will be in the garage later probably and will hook it up to see what it gives.
LOL. I saw that the other day.
Not quite what would be my situation. But if you can do that without mods I'm probably the guy that can do it.🥺
DRAGRCR
VICTORVILLE
MANGO D170
LOL, Marc, that is what got me started. Then I made the Airbag light bypass harnesses for a few Friends even though I did not need one myself. And, guess what. Now I have a 2020 RedEye and I had to make a set for myself.
