Have fog lamps been dropped for 2024 SRT392 DDs?
Hamsquatch
Warrenton
VA
2023 Durango SRT 392 Premium
Thread Starter #21
Again, thank you again READY GO. Ours lists, among other things, "ENGINE OIL COOLER" and "HEAVY DUTY ENGINE COOLING".
So my gut tells me it's a probably a cost cutting/ease of manufacturing thing, but who really knows.
I did not know our 23 SRT392 has the "AUTOMATIC HEADLAMP LEVELING SYSTEM" - so that's a plus. I knew our R/T TNG had it, since it was really geared toward the towing aspect, so this is a pleasant surprise. :)
Hamsquatch
Warrenton
VA
Thread Starter #22
@READY GO, Thanks again brother. I saved that PDF as part of my records. I'm grateful for the link and to have this now.
Mukwonago
2024 Dodge Durango SRT392 AlcHEMI-DG
Glad to help you out, that's what we're here for👍
I see no coolers or chillers in the ten page build sheet, but the Fog Lamps are listed. This is a Premium 2023 SRT.
Hamsquatch
Warrenton
VA
Thread Starter #25
That is strange, our 23 Premium with fogs lists, among other things, "ENGINE OIL COOLER" and "HEAVY DUTY ENGINE COOLING".
Then again, some of us got Alcantara roof liners in our 23 Premiums, and others didn't. I guess Dodge never disappoints in making em all a little "special" LOL.
Okay now looking at a more comprehensive report we generated at order. It has:
NHA - ENGINE OIL COOLER
NMC - HEAVY DUTY ENGINE COOLING
LTE - PREMIUM LED FOGLAMPS.
I am with @drag racer, these don’t really have an oil cooler like the HC, I sure don’t see it and the heavy duty engine cooling is probably a larger radiator than a 5.7. It runs too hot and needs a real oil cooler under my foot anyway. Soon it will help to just screw the warranty, get a tune and get it a correct thermo to stay at about 190 where they like to live.
But the LED fogs are effective and very useful IMO.
Hamsquatch
Warrenton
VA
Thread Starter #27
Per the previous post from SilverBillet, if I'm understanding his post correctly (I may not be), it looks like the 2024s also recite "ENGINE OIL COOLER", like my 23 build sheet does, so I suspect any further difference or similarity to HC systems for the 24 392s is speculation at this point. I may write to Dodge to see if they might have an answer, but it's actually not that important to me LOL, and thank goodness, our 392 runs pretty cool as-is. I'm not trying to engage in any arguments, nor complain about the function of ours - just wanted to point out I noticed the 24s seemed to have dropped the fogs.
When picking up an ordered Audi SQ8 I noticed that it didn't have fog lights like her previous Q8 did.
Mentioned it to the salesman who said "With these LED HID headlights there's no need for fog lights". Okay, I said, not about to argue about the usefulness of fog lights' lower position, or that it's either LED or HID, but not both.
Mukwonago
For my 2024 SRT392 AlcHEMI, the Build Sheet Data shows "Heavy Duty Engine Cooling" and "Engine Oil Cooling"...the "EOC" is the coolant, sandwich/plate-style cooler...which actually help heat up the oil faster at start up, then does slightly cool down the oil when it reaches the 220-235° temp since the coolant is at around 205-215° temp.
On my Challenger SRT392, I swapped in a 180° Thermostat and was able to set the fans to progressively kick in at 185/188/192°...way better temp drop than what the factory "cooler" does.
Here's a pic of my new Durango SRT392 oil filter and cooler...interesting to see the oil filter says right on it, "Factory Installed"!! (I was disappointed to see that it isn't an MO-0041 "White" (Wix) Mopar filter).
I've never seen one that didn't come with the regular black filter, and that said factory installed on it.
Then again, I never had a Viper.
Mukwonago
I thought I remembered my 2015 Challenger SRT392 coming with the White Filter..but I could be remembering wrong 9 years later.
I'm thinking to do a 500 mile oil change and swap over to the White Filter (I really like the White Filter better) and Penz Ultra Platinum 0W40..I just got a Fumoto F106S valve yesterday for it.
Here's what I did for my 2024 Laramie G/T..I'm lazy as sh*t🤣
Mukwonago
I'm thinking to drain, clean, and keep the "Factory Installed" oil filter as a cool sovereign..I also have never seen one like this before.
