Hellion Twin Turbo kit…..going from Maggie 2650 to turbos…..
I kept thinking SRT was going to release a Challenger with the Hellephant power plant and was gonna upgrade, so I didn't wanna get too deep with this one. With that looking less and less likely this one may get drop in pistons and a sprtiz of the happy happy at some point though LOL
Thought you had the upgraded RE short block (with supposedly better/forged pistons). Won't take the shot?
I didn’t spend 20 k , you don’t have to buy all them so called go fast parts to go fast you just have to be resourceful
Im thinking you could put a parts list together, totaling less than $15k, that’ll get an 8 in good air without the bottle. The rest of the budget goes to seat time, week over week, figuring out how to do it.
I agree I figured up what I did to my car and it’s less then 15,000 if you can turn your own wrenches and get at least -500 da but weight reduction is where it counts the most
The RE long block is claimed to be 30% stronger (whatever that means) from what I remember reading. However, I'm already pushing quite a bit on the E85 tune, adding another 100 "may" be OK for a while but having already had one event I wanna avoid another LOL.
If I remember you weren't all that aggressively modified either...
After looking at these sheets from allpar it's only a matter of time until I join the same boat.
Screw it. Still going to send it
I was at 1000 hp and over 1100 torque on my 2018 and I ran it all year and upon disassembly it look phenomenal
Yeah, that's what I was gonna say for the stock motor. It can only take so much. I have no clue why mine failed as I wasn't doing anything all that crazy. I was running a 2.72 pulley with ID1000s and a tune that maxed out at like 10deg of timing for 93. Playing around with shift points at the track we overshot on the 1-2 shift a couple times and hit 6900 or 7000 (can't remember) but that didn't happen more than a time or two and was months before the engine actually broke. I've heard a lot say not to take a stock motor either Hellcat or RE past 850 wheel but lots are doing it. I don't know where mine's out now but enough for about 140MPH in the 1/4.
The OST shop car is still stock motor and all it sees are 1/4 mile runs LOL. Mike and I laugh about that all the time. Here I was conservative and blew up.
FFBOS
FFBOS
Mount Prospect
2016 Hellcat Charger
Thread Starter #68
Most are good to go. Tune is key and “customer responsibility“ as well.
A lot of e85 cats live at the 900 wheel range. I was there for probably 250+ full WOT hits and when we took the motor apart it was super clean. Only reason we dug that deep is because I somehow broke a cam phaser. Still puzzled how that actually happened, but when it was out we did a forged 6.2L short block. Manley rods and Diamond pistons, but they only rate those to “900 wheel“ lol, but many push them much much farther.
I've heard from several that e85 gives a lot of safety margin. Maybe the extra volume being a cooling effect.
FFBOS
FFBOS
Mount Prospect
Thread Starter #70
It does. Most of the issues guys run into are dumping whatever e they find into it on a hot tune, e85 timing doesn’t necessarily play well with e50. Rich condition can cause issues.
You really have to try to blow something up on E85. It is very forgiving but at the same time very hard to tell when it's actually knocking without it falling on its face (without a dyno of course)
Because of that cooling effect amongst other things we were able to squeeze 460 out of the Busa completely non intercooled on E85
Demonic Cat
Mid
RI
Finally someone going turbos. It will be a whole other animal now.
The key 100% is the builder and tuner.
I would have switched over to turbos, but I’ve got so much into my car there’s no way I’m switching directions, if I’m gonna drop that kinda coin again I would just get another car to turbo. Which is what I’m doing lol.
Good luck with project. Can’t wait to see how it comes out.
I think a member here already did it compound boost style. Southernmincat had an Idigo Blue Challenger RE with 1320 HP. Easy for me to remember that number like 1/4 mile in feet. I think it was done up w/ Hellion build, and the results were good.
FFBOS
FFBOS
Mount Prospect
Thread Starter #73
Yea, his setup is stout for sure.
Demonic Cat
Mid
RI
If I recall he said traction was still problem even at speed, the image I recall was Michelin 345s. With that kind of power I am not surprised. Believe he put it up for sale and was going more in the direction of street/track car.
FFBOS
FFBOS
Mount Prospect
Thread Starter #75
He had the ability to dial it down however he wanted. Crazy he wanted to get rid of it. I daily drive on 17’s with 315 ET Street R’s. The only tire that can make it manageable once you get past 1000wheel.
If it was sold just after build there were problems I'd say. Seen it many times.
So you never actually lost the motor? I remember that thread awhile back on your rebuild, I don't remember or maybe I just didn't backtrack to read the reasons and I assumed it went south after 20Kmiles and all the 1/4 mile runs. That actually turned me off to the pure E85 tune idea. I was like "ahh ya' see problems long term". But now...?hmmm. I can't get a flex tune from Truestreet over here on L.I. (they don't offer it anymore) so I'm bringing it in for a straight pump gas tune this weak. I don't think I would like the dedicated E85 tune because of being pigeon holed to only finding stations that run E85 and then I can't go where I want when I want, hence I wanted the flex. I also don't have the tech capability of doing a remote tune, so it is what it is.
Demonic Cat
Mid
RI
Thought he said it was dialed in without problems other than traction, and he was going a different direction for car set up. Mainly for rear for traction to go street strip was there issues with it. I kinda took it he was going more like Mark W set up. Was there a build problem with the compound boost
FFBOS
FFBOS
Mount Prospect
Thread Starter #79
I think he overbuilt the car.
What I've seen historically being around these cars for more years than I wanna remember and seeing a LOT of builds, when the owner sells the car right after it's done, there's been some kinda weird problem and they cut their losses. Murdercat on this forum is selling his after going rounds with it as just one example. Hopefully that's not the case, but just been what I've seen more often than not. Why spend all that time and money and then change directions I guess.
